DutchmenSport
Aug 27, 2019Explorer
Pretty much as Lynmor said. If the appliance is running and working correctly, then there's nothing wrong with it. You could run an independent extension cord into the camper and plug each item in individually and make sure everything is running as expected. Then plug in your camper and with a volt meter, check each outlet. If the volts are correct, that's pretty much all you can do.
Progressive makes dependable and reliable surge protectors - EMS power watchers.
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 22, 2026
