joshuajim's avatar
joshuajim
Explorer II
May 22, 2016
WD shanks
I need a longer shank for my Equal-i-zer so that my tailgate will clear the A frame jack. In researching several of the major manufacturers (Curt, Eaz-lift, Equalizer etc.) the prices vary from about $70 to $150. All that I looked at are rated at 14,000#.
Why the big differrence in price for similar shanks?
  • LarryJM wrote:
    IMO the reluctance of the OP to give us the info about which specific shanks he is talking about tells me this is most likely a BOGUS question and is a troll post.
    Larry
    I guess that means that you can't answer it... so spin it!
  • IMO the reluctance of the OP to give us the info about which specific shanks he is talking about tells me this is most likely a BOGUS question and is a troll post.
    Larry
    Simple, different manufactures set different prices, that's just way the world works. Same as one store selling an item for $10 and another store selling the exact same item for $15.
    They want the money.
    Businesses set prices by what they can get and make as much profit as possible. There is nothing wrong with that, you can buy from those that give you the best value.
  • joshuajim wrote:
    Huntindog wrote:
    As already said, we don't know what you have been looking at.
    I will say that there are different grades of steel. I have even seen some shanks that appear to be cast. They tend to be cheaper.
    I do not know if any of this applies to the ones you have been looking at, but it at least gives you some questions to ask about the materials used, so you can decide if that is the reason for the price differences.
    As per my previous post, all the shanks are made by the major manufacturers and are of similar size and construction. Even if I provided specific items, no one would be able to decern the differences from a picture or manufacturers data.
    The steel is of no consequence as even the lowest grade of steel including cast steel would have a tensile and shear strength of over 100,000# for a 2x2 bar. The suspect items could be weld quality or or possibly fatigue failure. Fatigue failure is not likely as the bar is only subject to a very small percent of its 100,000# capacity.
    Now given the above information, does anyone have an answer?
    Same answer I already gave you. Some manufacturers DO use higher grades of steel... Whether it is needed or not IYO. They tend to be higher priced. Whether it is worth it to you or not is totally up to you.... Many people are happy with the local auto parts stores tools... Others prefer Snap On.. Both will do the job. Your money, your choice...
    OTOH I suppose it is possible to over pay by paying a premium price for a shank that is not made of the better steels... That is why I suggested that you inquire about that.
    Since you now say that is of no consequence... Just buy the cheapest one you can find.
  • As already said, we don't know what you have been looking at.
  • Because that is the way it is, different manufacturer, different price.
    Same as one store selling an item for $10 and another store selling the same item for $15.
    Without giving the actual references to the shanks you are talking about your question is IMPOSSIBLE to answer with any possible level of accuracy. That's like asking why one 3/8" drill costs $50 and another similar 3/8" drill costs $200 ... not the greatest example, but illustrates what I'm trying to say.
    Larry
    They are all 2x2 solid shanks with the same length and approximately the same drop and rise. Does that make it clear to you? This isn't rocket surgery.
    Larry
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
