GULFMAN's avatar
GULFMAN
Explorer II
Sep 24, 2013
We have a ghost in our Bigfoot TC 2500-9-6
We seem to be experiencing some kind of electrical problem when connected to shore power only ( with the red wire (+) to the battery disconnected) when we turn on any 12 volt power source (15amp) the radio (Kenwood) will turn off and then a second or two later it will turn back on this happens with any 12volt circuit you choose the best I can tell is that the original radio harness which is located under the TV cabinet behind the pull out drawer is connect to the two 30amp “Polarity” fuses along with the propone and carbon monoxide sensors but if I reconnect the battery wire and turn on the battery disconnect switch while still being connected to the shore power the problem does not exist or just being on battery power alone the problem does not exist. I think my problem may be with the PARALLAX 7300 series model 7345 converter. Any help you can give would be greatly appreciated.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
