enblethen
Sep 22, 2013Nomad
How does the other propane appliances work? Turn on stove top with at least two burners lit. Could be defective regulator if they do not burn blue.
Ys, it could be clogged orifice if other appliances work properly. Soak in alcohol, then blow out. Do not use pins or needles as they can damage the small opening.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
