boubou64's avatar
boubou64
Webber Q 100
Switched from the green propane canisters to the proper hose for the Webber to use on a 5lbs propane tank. No extra changes were done. I light it, it works but the flame is blue and very low, just stays close to the burner. After a few minutes, it gets normal.
I've done this a few times, tried cleaning the burner, it's clean and still does the same. No problem with the green canisters.
What am I doing wrong?
  • While the OP's issue seems to have been resolved other Q100 / Q120 owners should be aware that for a time the regulator used on this Q series of Weber grills failed at an alarming rate, displaying the same symptoms the OP described. I replaced the regulator on my own Q100 twice under warranty, again on my current Q120 also under warranty, even recently replaced the regulator on my Q220 twice now even though it's a different model regulator. I suspect these regulators were all manufactured in the same Chinese factory and all (for a time) suffered the same failure rate.
    Any Weber owner should also note that the tank > grill adapter hose sold by Weber has a noticeably larger opening on the 1"-20 threaded fitting that screws into the grill's regulator than do third party hoses that otherwise "look" the same ... so if gas flow is an issue with your Weber that too could also be a reason.
  • Try this
    connect larger tank to weber q
    I made this change and no longer have a problem using a larger tank. I also purchased an adapter that fits the connector that goes to the tank that converts it to the small one pound bottles so I can use the smaller bottles in an emergency or when I don't want to pack a larger bottle along.
  • I believe those of you trying to use the grill off of your trailer are using a LOW pressure line that is not compatible with any grill with a built-in regulator. It must be hooked into a HIGH-pressure line before the tanks regulator to work correctly. There are ways to convert grills to work on LOW-pressure. Search the sire for how to do. Good Luck! Chino.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
