wa8yxm
Aug 12, 2016Explorer III
I am guessing you have a Magnetek 6300 Power distribution panel/COnverter...
WHY? Well this converter is kind of unique, it contained both a very slow DUMB type battery charger and a very poor "Converter" for lights and things that did not need "Clean" DC.. A relay (which may have failed) selected BATTERY or CONVERTER supply for the lights. Either the Relay or the high current converter has failed, so you only get lights when the battery is selected.
The solution: If you have this unit get a Progressive Dynamics 4600 series from Best Converters.. Make sure you get the magnetek upgrade kit which includes some jumpers to bypass that flakey relay. your batteries will thank you and ultimately pay for the upgrade by not failing as fast.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
