MEXICOWANDERER
Aug 12, 2016Explorer
Wa8yxm,
A ferroresonant AC to DC converter WITH a 30 watt 3 ohm power resistor as a bleed resistor going to the batteries. Wonderful. A full battery meant 14.7 volts going to the accessories. A discharged battery meant 12.4 volts going to the lights. And BW Magnafart, used the most garbage grade of power caps, multiple ceramic power resistors and no fan cooling. Fred Flintstone grade engineering. Three point seven maximum battery charge rate.
Like entering Elanor Roosevelt in a beauty contest...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
