gaetzchamp's avatar
gaetzchamp
Weird Electrical Issue in PUP
I have a 1999 Coleman Westlake PUP. I'm having some wierd electrical issue that I need help with.
The PUP works perfectly when hooked up to battery power, but when I plug it into the house or run it off my generator, my interior lights or water pump wont work. The 110 outlets all work though.
I have checked the 5 fuses on the inverter and have even swapped them out and that doesn't work. I've popped the breakers on and off too. Still no lights/pump.
Thanks in advance for your expertise.
Tim
  • Some of these older PUP's had a converter/distribution panel that were wired to either charge or to use battery. The ones I've seen had a manual switch but yours might have an automatic switch.
    Post up the brand and model of distribution panel and maybe others can nail it for you.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
