enblethen
Jan 24, 2017Nomad
What chassis?
GM feeds to the starter and to the battery control center. The battery control center feeds through the battery disconnect then to chassis items.
Fords feed to a starter relay with fuse links feeding chassis items.
When you turn on the key to on, does the dash light up?
When you go to start do you hear a good click?
There should not be a big drain as you indicated. I would diconnect the large post on the alternator to see if it goes away.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
