rk911
Jul 24, 2015Explorer
enblethen wrote:
Check to see if you tripped a GFCI receptacle.
Use known good appliance in receptacle to test for presence of 120 volts AC.
X2 on this and fyi you may find more than one GFCI receptacle and you may find them in storage compartments and other places you might not expect to find them.
or just plug in a fan, work light...anything like that to see if the outlet is actually working. if it's not check for tripped GFCI; if the outlet is working try a different outlet and/or charging cords.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
