WaMike's avatar
WaMike
Weird noise! I know. I know but need help!
Hello All,
I know you probably heard this a ton but I need some assistance with this strange noise. I have a 2019 Coachman Freelander 28bh and it is making a strange noise. It starts after 10mph and continues but the wind noise drowns it out on the freeway. At 10mph it starts slow then speeds up at 20mph and keeps same rhythm. The noise itself sounds like a hand crank wind up radio and is coming from between the fridge and oven. Infront of the rear passenger wheel well.any help is appreciated! Thank you.
WaMike
  • Drive very slowly with someone walking along side. Is it a click, click, click sound that speeds up as you step on the gas ? Could be a bearing going bad.
  • Wow you guys are detectives! That gives me a great direction to move towards. Car noises scan be very cryptic and that was my best guess on noise. Check out the video at 5:00. https://youtu.be/KEuRPZqOdC0
    I will start poking around when I can get to my rv. Thank you all!
  • "wine DING" sound ?
    Like one of those emergency survival radios make
    When you crank the handle to charge it up,
    Same thing for those little emg flashlights
    That's wind noise, you have an air leak around the fridge between the inside and outside
    You might want to remove the roof vent cap and look for some thing that is deflecting air down into that area
  • Hand crank wind up radio?
    I'm only 60 and curious if a better example can be had.
    Don't care for weird noises myself but can't wrap my head around what that sounds like.
  • JaxDad's avatar
    JaxDad
    Explorer III
    WaMike wrote:
    Hello All,
    WaMike
    The back of the fridge is vented to the outside and thus lots of moving air. I’d wager you have a panel or some heat shielding that’s a little loose and is vibrating.
    Open it up as best you can and with someone on the inside begin tapping in different areas and at different levels of intensity.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
