12rvjoe
Sep 30, 2013Explorer
Welding on TT
I am wanting to do some welding on my TT (2012 crossroads) and I was wondering if I need to unhook the battery before doing so. Also is there any other precautions needed to protect the elec./comp. sy...
69 Avion wrote:
I have seen people building trailers and they were lazy and used the steel jig for the ground. It made it easier to move the trailer because they saved a few seconds that it took to move the ground when flipping the trailer over. Once the axles were installed they would flip the trailer back, right side up and finish some welding. The trailer was grounded, from the jig, through the steel hubs to the trailer. The new owners couldn't understand whey the bearings didn't last long.
As far as disconnecting the battery, it is just a precaution that I take. If you don't have any sensitive electronics then it probably isn't an issue. I would rather give advice using caution instead of costing someone a lot of money because they took a short cut. YMMV
