suprz's avatar
suprz
Well good thing i checked but....., DARN!!!!!
:M. Cranked up the A/C today, just to make sure all was well... But it wasnt! It runs, blows cold air, BUT... Is making a heck of a noise almost sounds like something in the squirrel cage fan... So up on the roof i go, after taking it apart, and looking at it, checking it, etc.... I turn it back on without the shrounds on either fan and it is still making noise.. Sounds like it is either the motor losing a bearing, or the compressor making a racket.. But either way, i am going to get it fixed before our trip to florida this sept. The unit is the original that came with the coach. A Carrier 15,000 BTU ducted with a remote control unit. I checked and i know they no longer make this unit, but there is a conversion kit for a coleman unit that allows me to keep the original grill, and the remote. YAY!! Better than that is my extended warranty covers the A/C unit (per my paperwork and contract i have on file ) with a $50.00 Deductible :B. ... Now, the bad part is having to try and get a appointment to get the rig in. I bet that they are doing a lot of A/C units seeing how its July..... I wonder how many weeks they are behind.... :h
  • I got ahead of myself so this is edited.
    The inside blower may be a squirrel blower.
    When ours unit stopped working the fan inside still blew but at low volume. When it finally locked up the capacitor made a lot of noise trying to start the unit before stopping.
    The inside fan made no noise to be noticed.
    So tun only the fan on. If it blows then your problem may be with the unit cooling fan as described below, in the roof unit.
    The cooling unit fan has a large flat fiberglass reinforced disc with blades at the end on a vertical shaft.
    Ours began making more noise than usual when we pulled out early last month.
    Sounded like something was (in the squirrel cage)when starting and then a good bit of the time. Finally it ad a heck of noise and we thought the ac had seized up and a new one was going to have to be installed.
    In Shawnee Coleman was there and when we told them what happened they were on the roof and pulled it apart. The fan had slid down the shaft after 13 years and ground itself into the base pan and locked it self up. They replaced the fan blade/disc and put an extra set screw below it, in the shaft. It won't come loose again.
    Now your problem may be entirely different but this is a possibility.
    He said the Ac units themselves very seldom go bad.
  • Small update, I checked again and the noise is there without the compressor being on, so it's the motor
  • 2112's avatar
    2112
    Explorer II
    My last fan motor lasted only four years before the bearings started to fail. It does make a heck of a racket. I replaced it a few months ago in about an hour. You had the cover removed so you were six screws away from having the motor removed.
    The motor itself cost me $110. I also had to acquire a long hex T-bar to loosen the squirrel cage set screw.
    This unit, is ridiculously easy to work on. I could take the motor out within 10 mins. The hardest part is undoing all the **** screws holding the cover on! I think there is at least 15 of them holding that one. But, i havent found a replacement motor online yet. At least not one branded "carrier airv replacement blower motor"
  • 2112's avatar
    2112
    Explorer II
    I provided my local RV sales/service/parts dealer with the AC model#. He looked it up and had the proper motor in stock.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Had that happen to a neighbor across the road from me in a campground,, Late Friday.. I helped him remove the inner cover over the blower and he found the hub was cracked and the thing was ratteling like you'd not believe.
    now 1: Carrier (A Trump corporation) is no longer making RV A/Cs thankfully the blower is a more or less standard 3rd party item
    2; Over an hour to the nesrest Camigng world from where he was parked and that mens no way is he getting to a parts store before closing
    3: IT WAS HOT!!
    So where is he getting a replacement? My basement of course, I kept the spare parts when I replaced my 1st carrier.
    I have since replaced my 2nd carrier
    Parts are yours if you are in the Flint, or St. Clair (next week Michigan.
    3: IT WAS HOT!!
    Thanks for the offer. But we wont be close to MI till next year sometime. I did notice just now some wiggle on the squirrel cage fan, and the screw/ bolt that holds it on is tight with some sort of a dried blue liquid on it. ( im guessing some sort of thread locker). But the fan itself shows no signs of any cracking. And the wiggle is coming from the part of the fan that attaches to the shaft of the motor. How much for the squirrel cage? :B
  • I'm now leaning towards just getting a new unit.. Called and made an appointment at the RV dealer I bought the RV at. Called my warranty company, they confirmed that they know they stopped making the unit, and that they would cover the new unit and the conversion kit in full less my $50.00 ded
    I guess it makes more sense to get a new unit for $50.00 than throw parts that may cost that much and still have a 11 year old unit
  • I replace my "bad" carrier with a Atwood Air Commander heat pump. The only hard part was getting my son to help me move the new a/c to the roof
    Since the carrier had a wireless thermostat. I had to run the new thermostat wire. Somewhat of a problem, but was able to by removing the 1" strip that covered the seams in the ceiling paneling I was able to drill a hole to pass the wire through to the same location as the old thermostat.
    The good part, I sold all the good salvageable carrier parts on eBay so the new A/C only cost me about $100.00.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
