GordonThree's avatar
GordonThree
WEN Gen on sale
Few weeks back someone posted they missed out on a sale Amazon was running on the 2000 watt WEN generator.
The generator is back on sale. 2kw for $389 and $5 shipping.
Find it here through Amazon's "deal a day" website:
www.woot.com
  • Generator arrived.
    Very Impressed more so then i thought i would be, very high quality, ran everything i threw at it(air compressor, 2HP abrasive saw,1500 watt heater and shockingly all on eco mode), sinewave is pretty much perfect even at max load, and frequency and voltage are dead on. i did not have my db meter with me though, i will have it in a couple days if anyone actually wants the numbers
    impressive overload, probably a good 5 seconds in overload before it kicked the power off(nice compared to my big generator which just goes to 50 hz and 100 volts when overloaded)
    already gave it a oil change at 2 hours and it was quite shiny in the oil
    only con, you need to remove 3 normal philips screws to check the oil, annoying will prolly replace with wingnuts, and none of the outlets have any form of dust covers or water shields
  • GordonThree wrote:
    northshore wrote:
    When reading about this generator, it says its quiet, 51 db which is great if true, the honda 1000 states 59db. So who has one and is it that quiet???? have you had any problems with it?
    I'm guessing the Honda measurement is no load, eco switch off. The WEN measured no load, eco switch on.... or they measured from a different distance, or just lied about the number.
    Appears to be using a Yamaha motor, which is a bit quieter than the Honda.
    one reviewer is claiming 61db, i have a meter i can check it out, but if its even close to the honda, its fine for me
    i have no trouble sleeping through my 7k predator generator, so this is miles above that
  • LittleBill wrote:
    op, thanks for the link, was ready to pull trigger on a champion, this was alot cheaper and has solid reviews on amazon. i don't rv this is a supplement to my bigger generator
    thanks, i did buy it
    Glad to hear it! Let us know what you think of it when it arrives.
  • op, thanks for the link, was ready to pull trigger on a champion, this was alot cheaper and has solid reviews on amazon. i don't rv this is a supplement to my bigger generator
  • When reading about this generator, it says its quiet, 51 db which is great if true, the honda 1000 states 59db. So who has one and is it that quiet???? have you had any problems with it?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
