dtappy3353's avatar
dtappy3353
we're boondocking
There is a 30 amp fuse that serves as the battery disconnect for our 2 12v deep cycle batteries.
When we run the generator and plug in trailer the 30 amp fuse blows. We are unsure if generator is charging the batteries correctly.
When we run the solar system the batteries will charge and the fuse will not blow. Yes, the converter is unplugged when we use the solar.
The battery indicator panel inside the trailer only shows 2/3 or "good" but the hand held volt meter shows the batteries read 11.8 and 11.94 each.
What are we doing wrong?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
