MNRon's avatar
MNRon
Westinghouse i4500 Generator
I posted a few weeks ago about trying to run my AC with a Yamaha 2k genny and Magnum 3000W boost inverter. Sort summary - the Yamaha just wasn’t strong enough with surges to work.
So now I’ve purchased a Westinghouse i4500 which we just picked up today in Salt Lake. It’s 100deg out so I expected I could run my AC, maybe both ACs with the boost inverter…no joy :(
Altitude here is 4200ft so I don’t expect the full 3.7kW static performance but still it should start and run an AC!??!!
By playing around with Magnum control settings I can nurse the genny (with Magnum boost support) to start one AC once in a while (Magnum VAC dropout=60v, AC input limit=20A; manually start AC fan on low early; etc). Still have to futz with it a dozen times or so to get success. When running the Westinghouse shows it’s providing 2.3k power (AC, fan, converter).
But even when I nurse it up on one AC it only ran an hour then kicked out, a half hour the second time. Just spent 10min getting things going again, hopefully longer this time but we’ll see. When it kicks out the boost inverter takes over and keeps the AC and fan running by drawing about 170A from my batteries. Not sure why genny kicks out as it doesn’t show overload, just reduces to 0power and the Magnum timer to kick it in starts dancing with the genny but it doesn’t ever come back in.
As I’m typing, the genny just kicked down to 1.3k power and my Magnum is supplying load support of 50A from batteries for a couple minutes; then genny went back up to 1.7k and is running the AC on it’s own again.
Anyone have a clue what’s going on, and why the Westinghouse can’t start and run an AC on it’s own?
  • Itinerant1- thanks again for all of your help in understanding this (and 3 tons too). I spent more time on the phone again yesterday with another Magnum tech. He didn’t seem surprised, and pushed that the problem is I’m not using a generator that’s 2x the kW of the inverter!?!
    It’s clear to me that the Magnum algorithm to accept incoming power integrity is not tolerant of the momentary slump that generators have under high current impulses. It also sounds like this design flaw is not limited to just Magnum. I’m a little surprised that they don’t seem to care, and don’t expect that people buy generators snd hybrid inverters assuming they play together better and load support is as simple as addition.
    With your help I’ve purchased a larger genny, and turned my Magnum to optimize it’s performance in this respect. I’ll be adding soft starts and then expect I can improve the odds of running AC on the genny (through the Magnum; pass thru, or load support) to where it’s no longer an issue.
    This forum is great, thanks again.
  • 3_tons's avatar
    3_tons
    Explorer III
    With advice like “two times yada, yada” Sounds to me like the phone answering guy at the Maagnum is passing the buck…
    My ProSine inverter is 2000w (4500 surge for 5 sec), and my genny is 2200w, but either on their own (including genny in Eco mode) will start and run an 11kbtu Coleman Mach1 p.s.without a hitch…
    Note, the problem I WAS having only occurred when genny was in Eco mode while passing thru the smart inverter (whether inverter was in standby mode or off)…Regardless of programming the inverter was not happy…Thus the added ATS solution that ends all nuances and provides even greater operating latitude - the simultaneous use of air conditioner, microwave, etc…..
    Either way (regardless how one might look at it…), the generator is on-line and assigned the same tasking (or LESS if operable in Eco), but with the added ATS, neutered of unnecessary proprietary software glitches…
    At least from an experienced process point of view, that’s how I see it…
    3 tons
    Set the Magnum up to 37 amps input.
    My Yamaha Iseb starts my single air conditioner reliably after it has warmed up and will do so in eco mode. The range of wattage starts at 1200 watts and goes up to 1900 watts. I have the Magnum set at 27 amps to allow the boost from the generator to work.
    MNron I always see the red over load light on the Magnum remote--and that happened both before and after the microaire was added. In hind sight I would not buy the microaire.
    I found out well after I purchased the Magnum that they don't recommend running an air conditioner from it. If my inverter/charger fails again (it caught on fire), I will move to Victron or Outback.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
