cavie wrote:
Bird Freak wrote:
It seems my converter has decided to die. Anyone know if it has internal breakers or fuses?
I just found the problem a few minutes ago and can't trouble shoot for a couple of days.
If I have to replace would you go with another WFCO or a Powermax? 8875's have been discontinued.
It has a 15 amp 120 volt circuit breaker in the power panel. The convert will not be on the GFI circuit. There also are Two 30 or 40 amp 12 volt reverse polarity fuses on the converter. There is also an inline reset-able fuse within 6' of the battery.
The WFCO converter on my Fleetwood product did not have it's own circuit breaker. It simply plugged into an outlet. I'm not even sure that outlet went through a breaker, aside from the main breakers for the whole RV. I've never seen this inline fuse either, and I've combed through this trailer thoroughly over the years.
