BobnSofi's avatar
BobnSofi
Converter !!! LOADING UP GENY !!! WFCO WF-8875
Hi All
In recent months we would run our 1996 Onan 5500 Marquis Gold
at about 5-10 mins it would !!! LOAD UP !!!
LOAD UP... DEATH LOAD UP... STRUGGLE TO STAY ALIVE LOAD UP
I thought it was a spun bearing in the geny armature, that would grind once hot
We have been turning off breakers, and we ran both a/c units for 20min... thus a HEAVY LOAD...
NOTHING... NO GENY DEATH LOAD
We have a WFCO WF-8875
It has been a GREAT CONVERTER... PUMPS UP THE HOUSE BATTERIES GREAT
Just ran it solo... Yep, it stops charging and loads the geny up
The WFCO WF-8875 is on a 15 amp breaker... A wimpy 15amp breaker
Have any of you ever heard of anything like this?
  • He said that he ran the 15 amp circuit solo, (doesn't that mean by it self?) and it fully loads the 5500 watt genset.
  • Water heater electric element, plus full charge from converter could be close to 3000 watts and are on different circuit breakers in your distribution panel, but all are on the same leg/winding of the Onan
    The a/c will be on the other winding/leg
    Trying to power everything but the A/C can be too much for that one winding
    And yes the converter or batteries could be bad
    You need to test
    Turn off water heater, turn off fridge, the try converter
  • It might be possible for the converters power factor to have gotten worse than it already is. The WFCO converter like many switching converters has a really lousy power factor which effects non inverter gens. Normally it is not a problem but perhaps in your case either the converter has gotten worse or for some reason the gen is more susceptible to the problem. I don't think you have much of a choice here but to replace the converter. In your case I would replace it with a converter that is power factor corrected.
    Sam
  • What you're saying is impossible,.....I don't care if a whole city is on that circuit,......a 15 amp breaker cannot overload a 5500w generator.
    Try again.
  • You can run the A/C but you can't run the WFCO converter,
    And the breaker does not trip ?
    You need to try a portable generator plugged into shore cord for testing and comparison purposes
    NOT SHORE POWER. ...You need to test with limited power so as to not burn down the RV
    What else is on that circuit
    One breaker on generator supplies whole RV except a/C
    Other breaker on generator supplies only the A/C
    Sounds to me like you are trying to run wh..fridge..And converter at same time, batteries are low or bad too much power draw for that circuit from.generator
  • smkettner wrote:
    Stops charging and loads up the generator? 1000+ watts of heat in the small box should release smoke in a minute or less. Must be something else going on.
    Are you sure the battery is OK?
    Does the generator run the electric water heat OK?
    Could it be a fuel filter?
    X2. You'd smoke that converter in a matter of minutes or trip the circuit breaker
  • Stops charging and loads up the generator? 1000+ watts of heat in the small box should release smoke in a minute or less. Must be something else going on.
  • 15A circuit S/B fine as it only draws 13A (or roughly 1300 watts).
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
