Randemgun's avatar
Randemgun
WFCO 8965 converter
I have a 8965 WFCO converter and a Onan 3600 generator for my horse trailer living quarters. Here are my symptoms. When running the gen all the 110 side works but not the 12V side. The 12v only is working off the battery. When I cut the gen off and plug in to shore power nothing works. When plugged in to shore power I get 110 to all my breakers in the converter but none of the 110 plugs, the ac or microwave work. When I call wfco they tell me the 110 shore power does not go through the transfer switch and don't understand why nothing is working on the 110 side if I am getting 110 at the breakers. I also discovered that with my GFCI in the bathroom (which is next to the converter) that when the gen is running the gfci works as well as everything 110 and I have 110 on the black wires and nothing on the whites (when metering the white and ground BUT when I am plugged into shorepower I get 110 on all four wires. Blacks and ground 110, whites and ground 110 and the gfci does not work. Banging my head on this one so any help is greatly appreciated.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
