dclark1946
May 10, 2014Explorer
alliemac9 wrote:
@MNtundraRet - thanks! I'll do some troubleshooting! You're right, we've mostly relied on the idiotmeter. We have a multimeter onboard, but have generally taken the lazy route (and/or really haven't had much concern about the batteries as we tend to do a lot of driving and they never get very low). I bought one of those little meters that plug into a 12V outlet (which I know also can be problematic relative to accurate readings depending on having charged or used your battery within some period of time), but it turns out I have no 12V outlets in the coach.
So, we've just gotten along for the past four years with little muss/fuss other than making sure the water level in the batteries is fine.
There is nothing wrong with using the RV battery indicator as your first check on battery voltage. I use mine on a regular basis even though I carry two high quality DMMs. For example, I know that when I am plugged into shore power all the lights should be on. When I get up in the morning with no shore power when dry camping I should have all but one light on. Anything different from these two conditions means I have an abnormal condition and I need to investigate. I can do that all without getting my digital meter out.
Incidentally our 7 year old WFCO converter is still function nicely even though it has never gone into bulk mode which is no big deal for me. It charges my battery nicely when we dry camp for over a week Some day when I have nothing better to spend money on I may replace it.
Dick
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
