alliemac9
May 09, 2014Explorer
WFCO Converter/Charger Dead? How to tell?
Our RV is a 2007 that we purchased in 2010 (new from dealer, so it sat for a few years). So, it's had four years of use and we took it out last weekend for the first trip of the season and had some low battery issues - not enough to cause problems, but we'd never seen the batteries sit on "low" before. I thought the batteries might be at end-of-life since they are from Feb 2010 as well.
However, it looks like the converter/charger may not be working. When plugged in in storage, we used to be able to hear a noise when charging, and now we have low batteries and no noise. So far, we've checked the breakers, but not the fuses (assuming there are fuses).
It is a WFCO WF8955AN. Is four years of use (plus three sitting) the likely lifespan for a converter? Is there anything else we should check before calling it dead? If it's dead, is there a recommended replacement?
I'm planning to put a solar system on the RV this year - the panels are being shipped (632 watts!), but I still need to purchase the rest of the components, in case that somehow factors into recommendations.
Thanks in advance for any recommendations!
