normcjr_mi's avatar
normcjr_mi
WFCO Inverter 8835 8845 8855
A buddy of mine had me check over his WFCO inverter 8835 that was no longer charging. I found that Capacitor 10 which is a 25V 220Uf 105 degree rating was bad. This seems it could be a common problem as it is next to some power resistors that give off a lot of heat.
Just wanted to give anyone else a heads up, before replacing or tossing your old one.
They run about 30 cents at mouser.com :
Here is the link to mouser electronics.
  • Better off not wasting the time. The WFCO won't charge a battery properly. Tested ours and it never got above 13.6 volts. Doesn't go to boost and the absorb voltage is way to low. It's in the shed somewhere collecting dust.
  • I used Reynolds extra-heavy duty foil as a sheet thermal barrier. A spootch of adhesive on the ceramic power resistor. Dropped temp of the capacitor in 82F ambient from 126F to 103F
    A silent fan blowing across the resistor / capacitor area also works like a charm. Like 25db.
  • Thanks
    Electronics Intel is always good too have
    Many WfCos out there..I have the 98100
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
