djmikelExplorerSep 18, 2017WFCO inverterHi All, What are those two 40amp fuses for on the WFCO 8900 series. They are located between the big breakers for all the appliances and such and the 15 amp fuses for other systems. Thanks for th...Show More
time2rollNomadSep 18, 2017Those are the main output fuses. Commonly known as reverse polarity fuses.If you connect the battery in reverse the pair will open. Don't test it.BTW the 8900 series is a converter. An inverter takes battery power and makes 120vac.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
