Hi All, What are those two 40amp fuses for on the WFCO 8900 series. They are located between the big breakers for all the appliances and such and the 15 amp fuses for other systems. Thanks for th...
The fuses are in parallel on the positive DC output terminal so they add their amps. There is a loose relationship between the rated amps "size" of the converter and the total amps of the RP fuses. Variations exist among brands and sizes within brands. Generally, the bigger the size, the higher the total amps of RP fuses.
EG, my PowerMax 100amper has four 40s, my 75 amper has three 40s, and my 55 amper has two 40s, but my Parallax 55 amper has two 30s.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
