Hi All, What are those two 40amp fuses for on the WFCO 8900 series. They are located between the big breakers for all the appliances and such and the 15 amp fuses for other systems. Thanks for th...
The paralleled fuses are a higher rating than the converter's maximum output, so in theory the only way to blow them is hooking the converter to the battery backwards.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
