Hi All, What are those two 40amp fuses for on the WFCO 8900 series. They are located between the big breakers for all the appliances and such and the 15 amp fuses for other systems. Thanks for th...
and they work. My 1st rig before I knew RVs use Black as + and white as -, I was trouble shooting some issues (which turned out to be to small of wire) and hooked the batts up backwards. I let the magical smoke out.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
