MEXICOWANDERER
Oct 01, 2014Explorer
It'll be next to the Samlex inverter, the cheapowatts and 31 battery. salt air seems to precipitate around 5AM. This is inside a house where it is cooler than the rig. Everything goes under the bed. I would be a bit hesitant about applying conformal coating onto the WFCO because of heat. Speaking of which is it your opinion that maintaining a 5 knot breeze across those resistors would still render them as producing too much heat? The low ESR cap is on the list of things to buy at Willy's Electronics. They have Panasonic.
My eyesight is going to be amplified. A 3.5 diopter lens plus 4.00 diopter glasses. Forty watts actual of 5K LED lighting. A 4" hobby vice will hold the WFCO (I hope). If there is a will there is a way. Also getting a 1K three watt 15 turn pot. Hopefully to use with a balancing series resistor to synch both cheapos.
Down the road comes another Lifeline and 3 more cheapos. Hope they like being stacked with standoffs. Two pusher + two puller fans. Plus a couple of 5 volt fans to puff on the shottky heat sink.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
