time2roll
Sep 20, 2014Nomad
09FLSTC wrote:smkettner wrote:
Manual is says it right on page 6
If the output voltage drops below 13.2 Vdc, the converter automatically changes to a “Bulk mode” 14.4 Vdc
Are you saying this? You believe the voltage increases to bulk 14.4 when the unit sees 13.2 or less? Come on.
Quoted from the manual in the link. Not my words. Yes that part in parens somehow dropped.
I have tested it many times, always worked. Steady converter voltage of 13.3/13.6 then hit the battery with 160 amp draw forcing battery and converter voltage well below 13.2 volts. Stop load in 20 seconds and voltage steadily rises to 14.4 volts.
My words; The 13.2 in the manual refers to the converter voltage during initial charging not battery voltage just before you plug in.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
