lawrosa
Dec 02, 2017Explorer
Upon my readings what I found was these units will charge at 14.4 volts at full amps until..
1. The 14.4 volts is reached. Then the amps will start tapering still @ the 14.4 volts. It will continue I believe on what I read until about 15 amps is reached. Then it will go into 13.6 mode.
2. Or until 4 hour time limit it reached, it will then drop to 13.6...
I didnt do an amp test yet, but I did run the batts down some, to about 12.3, 12.4.. Turning on converter it went right to bulk mode by itself...
Im happy so far, but am curious to see what amps I can get out of this thing...And how long it stays before tapering...
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
