lawrosa
Dec 07, 2017Explorer
Ok.. well I am up to 1255-1260 this morning... 12 pm really.. Solar was putting .7 amps in @ 14.5 volts..
( as high as it goes for float voltage that I had turned it up last night to catch the sun all day)
I put the sears charger back on, and will for 4 hours.. Its putting in about 4 amps like last night...
I wonder if when doing my battery draining for my amp testing is why this whole thing has happened to my batts..
I was putting a 900 watt load on the inverter to drain the batts fast so I was able to perform my amp testing..
Thats about a 75 amp draw on the batts for a 1 hour time frame... What you all think about that? Can you draw too many amps from batts and cause damage?
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
