lawrosa
Dec 15, 2017Explorer
Just a question here... My wfco did it too..
I did some work in the camper by removing the top bunk and making shelfs here..
https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/29506544.cfm
With that said the PD 4655 is in float mode, and has been since it went into this mode whenever....
I had the heat on during my renovation.( Its 26F here in NJ)
I dont think the voltage drop with 6 led lights on and the furnace went lower then 13.1 -13 volts from my meter reading at the batterys...
It stayed in float mode during my 3 days of putzing around in the camper..
Should it come out easier? Is this normal? My wfco did it too. stayed in float mode..
If I remember correctly the wfco came out of float when I winterized the RV and ran the pump to suck up antifreeze...
Is there an algorithm to this?
Also since I have no way to know what time this goes into equalize mode at the 21 hour mark I have not seen this either..
I don't know how I would know other then being at the right place at the right time...
Thanks all..
Thanks all..
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
