Did I read somewhere on one of these posts that Progressive Dynamics makes an retrofit type unit that you can just replace the converter part of the unit an leave all the panel stuff alone pretty much...
THe 4600 Line of converters from Progressive DYnamics .. The unit is designed to be a bolt in replacement for man "Integrated" converters.. Basic chassis and box (optional use) with leads.. The difference between the 4600 and the 9200 is mostly the case.
