time2roll
Sep 20, 2019Nomad
Do you need a basic explanation of hot, neutral, ground?
Otherwise you pop in the breaker and wire same as the others.
Exact same wiring as your home except the neutral and ground bus are not bonded.
Be safe, unplug.
BTW code allows the main + 5 branch circuits max on a 30 amp panel.
Be safe, unplug.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
