cekkk's avatar
cekkk
WH Causing a Leak?
I turned off the water heater last night and this morning the water temperature was cool. To be expected. I turned the electric on and after an hour or so I noticed a small leak at a coupling coming off the hot water line. I'm thinking it was caused by some pressure build-up when the water was going from cold to hot. Does that make sense?
The leak had really already stopped. I have a vague recollection of this happening once before years ago but I may be wrong. I'm not sure that I want to start fixing a problem that may result in more problems than I have, at least not until it becomes a recurring problem. Comments?
