DrewE
Dec 29, 2016Explorer III
Dusty R wrote:
I like Deka also.
I understand that they make batteries for NAPA.
Two six volt in series might be better, but if you are in the middle of nowhere and one six goes bad, you are up the creek. But if you have two 12 volts in parallel and one goes bad, just disconnect it. You will only have 1/2 battery power, but you are not dead in the water.
Dusty
If one battery in parallel goes out, it's not unheard of for it to damage the other one too. Golf cart batteries are quite robust and rarely die suddenly; they have thicker plates than dual-purpose 12V batteries that are commonly used for RVs.
But yes, if one dies, you are in trouble, just as you would be if you had a single 12V battery that went bad. (Indeed, a pair of 6V batteries is just a single 12V battery that happens to be in two sections that are less inconvenient to manipulate than a single equivalent battery would be.)
I prefer the golf cart batteries myself. Naturally, others are welcome to have different opinions and preferences.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
