brulaz
Sep 26, 2015Explorer
My 5200# Al-Ko axles have a label on them that says "Plant 52 (La Grande)" and under that the part number starts with "T52D ULFL" then lots of numbers. At the bottom of the label it clearly says "Capacity 5200#"
My guess is that T52D refers to the plant number, not the weight rating.
When you replace the bearing, don't you replace the race as well?
I've re-greased bearings and replaced the seals, but never replaced the bearing and races. Getting the races in/out properly sounds tricky to me.
I see etrailer.com and Google/utube have lots of info on it.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
