ktmrfs
Sep 26, 2015Explorer III
myredracer wrote:
Timken or SKF are as good as they get? A frame shop told me few years the name of a good one made in Japan but can't remember the name.
This is the first time for me to be ordering bearings and seals for our TT. Do I just need the part number off our axles and go onto the bearing and/or the Alko's website? Do they come as a kit with nut, cotter pin etc?
A bit unclear on the info. on our axle sticker. Says axles are 4400 lbs and are T52D-H9. Alko's website says T52 axles are rated 5K lbs?
axle should also have a tag listing the axle weight rating and often a stamp as well.
Alko 5200lb axles normally have 12" brakes with 6 lug wheels, 4400lb Alko have 10" brakes and 5 or 6 lug wheels.
Also std ratings are 4400lbs and 5200lbs not 5,000.
the 4400 and 5200 lb axles use completely different bearings.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
