MEXICOWANDERER
Sep 28, 2015Explorer
This site is from down under but the info is good and compact for the Fort Worth Texas products. Been using LE since 1972. When I had a Willy's pickup and it spent the winters with the front tires submerged in snow melt and after 80,000 miles the bearings looked like I just packed them impresses me. Same for tie-rod ends, axle knuckles, drive shafts, spring hangers the 284 lube points on a Willys.
When water comes in and out the doors the vehicle is submerged.
This stuff made others lubes into sick jokes. BTW out of the majors CHEVRON is not the lube leader. Shell is. Sometime when you have a moment Google
SHELL FOUR BALL WEAR TEST
or
TIMKEN OK LOAD TEST
Chevron makes great urea-based gasoline additive. But LE's lubes are so superior to others it isn't funny. But they are a ----- to get to.
http://www.lubeng.com.au/3750-3751-3752-ALMAGARD-Vari-Purpose-Lubricant.php
or
TIMKEN OK LOAD TEST
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
