MEXICOWANDERER
Sep 28, 2015Explorer
Take a tapered roller bearing to four hundred plus degrees and you ain't going nowhere. Where do these HG Wells grade theories come from? The thermal expansion rates between 53300 bearing race steel and cast iron are stupidly different. Even at 400F.
Of course it may be perhaps I ruined a cupcake tin and partially filled each reservoir with "actual grease samples" then stuck them in an oven. What the labels on the grease cartridges claimed and what reality revealed was a shock. PS Mystik JP whateverthehell was the worst. It started smoking at around 430F.
I keep complaining about this but when Reagan de-fanged the Federal Trade Commission you is equal to arthritic three legged antelope on the Sarangeti.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
