myredracer
Sep 29, 2015Explorer II
jodeb720 wrote:
As it turns out I ordered two new axles (6000#) not AlKo's to replace my 4400#'s because I can't get parts for the 4400's correctly!
AlKo was bought out by Dexter last year FWIW... I think that's part of the problem.
The learning process continues. Our axles are marked "4400 lb". As you probably discovered, bearing and other part numbers don't exist for 4400 lb axles. Just found out that the rating applies to the weakest part on the assembly, which is the springs. So it's the springs that makes the rating, but the axles are actually 5200 lb ones which explains why the brakes are 12". Now to just verify the correct part numbers for bearings.
Am actually glad to find that we have 5200 lb axles. They are waaay stronger than what would have normally been used on our make and model.
The mud is a little clearer now. :R
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
