Lynnmor
Aug 09, 2021Explorer II
23hotrodr wrote:
I use RTV Silicone. Put some in around the coax and some in the boot to slip down on the coax and protruding riser. The RTV is more solid when cured and helps prevent the cable from pulling off the boot when antenna is rotated. Good luck.
That is what I use as well. A silicone caulk with adhesive qualities helps keep the boot in place.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
