enblethen
Jan 09, 2017Nomad
A quality multi stranded #4 should do you good. Normal wire size is based on amperage. Your 75 amp converter should work very well with the #4.
Good clean connection ground for the battery to the frame of the rig and the converter end. Use electrical grease on all connections to prevent corrosion.
You say numerous splices, are these simple straight splices? Why so many? Every splice will or can cause voltage drop.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
