wolfe10
Jan 09, 2017Explorer
Since you suggest no heavy loads, the heaviest load (i.e. most amps that will need to be carried) is your charger/converter (up to 75 amps) I agree, #4 fine strand wire direct from battery with fuse to converter output. Also upgrade the ground connection at the battery. Chassis is OK to use for ground, but make sure the metal is clean and shiny and you have a good connection there. If in doubt, use two grounds from chassis to battery.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
