SoundGuy
Jan 09, 2017Explorer
Here's a Blue Sea DC Wire Gauge Chart I used when installing my inverter. Chances are your factory wiring is no better than 6 gauge from battery to converter, a situation made even worse in my case as my converter is located at the far rear of the trailer :E ... no wonder my WFCO converter can never get beyond 13.6 volts. :R It works well enough for general use but I've since installed a stand alone charger within feet of the battery that can do an honest 14.4 volts on the battery through 4 gauge cable ... the battery clearly likes it and so do I. :W
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
