enblethen
Jan 10, 2017Nomad
You must consider the length of the conductors and their resistance.
The positive would be copper with more resistance then a welded frame. The welded frame will have no voltage drop that you would need to consider into the calculations.
Blue Sea is most likely figuring a boat where both the positive and negative are using copper conductors.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
