Gdetrailer
Jan 18, 2014Explorer III
Almot wrote:
With a shore power I wouldn't think twice, residential fridge is the way to go. For boondocking - no way, unless you love listening to your generator.
Brand doesn't matter - too much - as long as it fits. I would stay away from no-name knock-offs, they come up in big box stores once and again, and may have noisy compressors or other problems. Width is most often the problem, RV frig cabinets are not too wide. Open the outside lid and measure the cabinet width. Then go inside and estimate the height and depth to the best of your abilities, considering the trim. Then measure the trailer door width to make sure that residential will fit through. Shut the propane off and cup the fridge propane line - duh...
Simply not true.
There ARE MANY people out the FULL TIME BOONDOCKING with a residential fridge and they ARE NOT "listening" to a generator any more than folks who use a RV fridge. Basically adding a little more battery capacity pretty takes care of the problem (and you can not honestly tell me that you boondock full time without the aid of a generator at all).
It is not rocket science, there is no hocus pocus going on because the newer home fridges SIP the power. That Samsung uses about 100W of power when it runs and works better than any RV fridge.
Same can be said of nearly all home fridges, in fact home fridges are required to be energy efficient and RV fridges are not.
My 10 cu ft home fridge is run from ONE PAIR of 6V GC batteries, in fact my entire TT runs off the same batteries. I have no problem running fridge, furnace and lights for 24hrs without the need of a generator and STILL have some leftover capacity in the batteries.
Two pairs of 6V GC batts would give me about 48 hrs STRAIGHT without needing to run a generator.
This forum is so negative towards residential fridges it really isn't funny. I even seen folks drive one poster away from this forum a few years ago, it is a shame.
Almot, instead of posting such nonsense perhaps you should consider not posting at all if you personally do not like or want a residential fridge? I would rather see that than having myself post the REAL facts to straighten out your OPINIONS...
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
