Horizon170's avatar
Horizon170
What do I need for Roof sealing flat top?
I just had my rubber roof pressure washed and the Guy said "You should think about re-sealing before long".
Question 1------is Dicore self leveling good to go around the vents, antenna base etc.
Question 2--------What do I need to go on the vertical side corner seams?
Q3------I still have some (not a bunch)Eitherbond tape left over from a previous mishap but don't think I should use it for general sealing.
Q4-------Since the old self leveling Dicore is now clean I see no need to remove it.
Thanks for your opinions.
Marvin
    Marvin
    Dicor has both self-leveling and non-sagging sealant. If the sealant isn't cracking to the point of falling off all you need to do is reseal with the Dicor product.
    https://dicorproducts.com/product/epdm-lap-sealants/#specs
  • Why would you pressure wash a rubber roof? Mild soap and soft brush...possibly.
  • Almot's avatar
    Almot
    Explorer III
    #1: Yes. Or, a better choice: Geocel RV EPDM sealant. Cures faster, shrinks less and doesn't bubble as much as Dicor. The only (possible) drawback is that it cures fast, for those who do this on a hot day.
    #2: Don't remember, don't have this problem.
    #3: Etherna tape needs a very good surface preparation. If the seam is still good, not very complicated spot where it could tear etc, and you think that sealant will hold - go with sealant.
    #4: After power washer it is "sidewalk clean", not "adhesion work clean". I would go manually over each seam - immediately before applying Dicor - with a mild dish soap or rubbing alcohol (probably better since you won't have to rinse after). Don't overdo it with alcohol, it softens the sealant, let it dry a little.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
