dougrainer
Feb 26, 2016Nomad
Lynnmor wrote:dougrainer wrote:Lynnmor wrote:cannesdo wrote:
Why is one pink and one blue. Are the color coded for size? Am I safe if I go with the same color?
Yes the color indicates the wire size. Use the smallest barrel that will accept the bare wire(s) freely.
COLOR does NOT indicate wire gauge(size). You can get various Wire Gauges in almost ANY color. Now, if you are talking about the Crimp end fittings, yes, the color usually designates what Gauge wire it is designed for. But not in this case. Usually the color designates the BUTT splice connections. In this case the color is translucent, which will not indicate Gauge size. As evidenced by the Pink and Blue colors, which are the same gauge size. Doug
He was buying connectors, not wire. Good Grief!
I KNOW that. But as I stated, in this case, the COLOR of the existing connectors did NOT indicate the wire size. That is why I gave a detailed explanation on both WIRE and WIRE CONNECTORS. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
