cannesdo
Feb 27, 2016Explorer
Chris Bryant wrote:
If the fuse in the breaker box is lighting up, the fuse is blown- replace it. I would start looking for 12 volt power right where it hook to the furnace- should be a yellow (-12v, or ground) Red (+12v) and 2 blue thermostat wires, one will have power all the time, the other just when the thermostat is calling for heat.
If you are using the meter to check- make sure the leads are in the correct places on the meter- for voltage, not current. I also often use a 12 volt test light.
I mean the fuse is working. All the fused make the tester light up when I go down the strip. When the fuse is blown it doesn't light up.
I'll check the wires. Thanks for the info!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
