j-d
Jan 13, 2017Explorer II
Klueck wrote:
Thanks J-D. We are currently trying to buy a preowned fifth wheel to put on our lot in the Keys. We NEED a good 2nd air and many do not have them. Good post.
If you own the lot, and don't plan to move the fiver, little if ever, you can add an A/C to any vent you want, and wire another feed to the coach from your shore power supply.
Say it's a 30-amp fiver. Won't run two A/C's at once. You could leave the original wiring and A/C, then run a second feed to the coach for the second A/C.
If it's 50-amp, pull the fan or trim on your candidate vent and see if there's Romex and hopefully a thermostat wire there. If not, you could always feed the second unit with surface-mount "conduit."
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
